Access to drain pump on Siemens dishwasher
Hi
I have a Siemens SE26T252GB/01 dishwasher which won't drain. (The "check water" light comes on). I have checked all the filters/drains and I think the the drain pump is faulty.
I can remove the side panels but cannot remove the base to get access to the pump. Can someone help with instructions or a diagram please?
Many thanks
I wished someone had replied to yoru post as I'm having the same problem, the manual says pump or drain pipe could be blocked, but I'm having trouble even getting the drain pipe off to check it and the pump is clear, I've also watched a whole cleaning cycle and not once did it pump out water out of the drain during the entire cycle
