22mm gravity fed hot to 1/2" kitchen tap
hi,
I have a 22mm gravity fed hot water pipe that needs connecting (without much space) to the 1/2" kitchen tap.
Have looked everywhere and can't find a comp 22mmx1/2" bsp straight tap connector ( well found one place and then they sent me a 3/4" one which I discovered after dismantling the kitchen).
I have found acomp 22mm x1/2" bsp coupler but it doesn't look like a tap connector end more like it would screw into something not sure how I would convert that.
Or something that looked like I could reduce the pipe to 15mm with a bush thing (rings and olives) but this looked like leaks potential.
Can anyone offer an suggestions I know I can reduce the pipe to 15mm with a solder reducer but I don't have much space and would rather avoid this if possible.
Grrr.. thought I was going to get the job done today and now I'm back to square one!
Thanks in advance
