Hello to All,
I need some help I have a Worchester Bosh 240 Combi Boiler which has a fault, this being when hot water is turned on the unit fires up but after a short time it makes a lot of noise as it is ready to blow and the pressure goes from 1 bar up to 2 plus an switches off with a lot of burbling noise
. I had recently replaced two rads in the house and bled as needed to remove all the air from the system. Any advise would be most welcome.
Thanks in advance
Thanks in advance
