Water well garden hose location
Michigan
I have a 60 foot deep water well with the pump located underground in the well casing.
The pressure switch and pressure tank is located in the crawl space of my home.
The well is located next to my garden and the outside frost free faucet is on my home so I have to run a garden hose across the yard to water the garden.
Is it possible to put a frost free water hydrant next to the water well so the garden hose is closer to the garden?
I was thinking of just digging a hole by the well casing and installing a T adapter there to hook the frost free water hydrant there.
But can you install a water faucet before the pressure switch and tank?
Before the tank....no. Your hose bib at the well will only have delivery water from the pump, not your approx 70psi. after the tank.
