Washing machine drain is backing up
Hello all! My washing machine drain is backing up and I can't figure out why..
I bought my house a few months ago and it came with a 2010 Samsung VRT washer and dryer. First couple of uses, the washer leaked a little bit but stopped on its own after 3 or so times. I never determined (never looked...) the cause of that leak since it was minor and fixed itself. The washer then functioned fine for about 3 months until I sold it and installed my other set, 2012 Whirlpool Cabrio Platinum. The newer washer backs up in the washer drain every single time, and it is quite a bit of water. I have a 1" washer drain hose going into a 2" drain pipe.
I've poured Draino into it, I've used a short plumber snake (barely reached the trap) and pulled nothing out, and I've used one of those balloons that expands in the pipe and spray a small stream out (admittedly, I may not have used it properly or did any good with it). The drain pipe itself does drain water - I've put a garden hose in it on full blast and it didn't back up. I guess the washing machine just puts out water so fast it does back it up..
Any suggestions on how to troubleshoot this? I have almost no plumbing experience but want to learn and try to do as much on my own as I can. Thank you!
