Sub zero side by side 500 series
I have an older sub zero side by side that has a spring assist closing mechanism that moved after the right hand door was removed, has anyone ever replaced the spring assembly back into the frame area? sure could use some help here.
there is nothing on the sub zero web sites and I,ve not found a single thing or thread anywhere on the web addressing the spring install back into the chassis area below the door.
