pressurized well tank
rockland, ny
I am researching different pressurized well tanks to replace an old glass lined one that is glass lined.
My questions are:
* What is better a bladder or diaphragm to separate the air from the water? Bladder can be replaced?
* Should the air water separator be replaceable?
* Some separator claim to remove 99.9% of bacteria that could be trapped in crevasses?
* The necessity for a polypropylene liner to prevent a taste or order from steel lined?
* Which manufacturer do you recommend so I will have the longest lasting with the lease maintenance?
* Is a 40/60 psi pump cycle good for a two level 4000 sq ft home?
thank you!
