LX188 STARTER&SOLENOID PROBLEMS
When taking out solenoid to check out and after putting back in with key off, hook battery back up starter spins but does not engage engine. Had to Disconnect battery to stop. Kawasaki engine.
I know that when installing starter solenoids in Fords and Chevys it's an easy thing to overtighten the solenoid to starter wire as the studs are so large it seems as they need to be torqued but the size of them is actually for the purpose of electrical continuity. When the nuts holding the wire on these solenoids are torqued excessively, their internals bend to the point of contact and therefore negates the ability to switch off when the relay is open. The fix is to buy another relay and when tightening the connections, do so carefully.
John Deere LX188 problem 4
