Leak at through bolt on toilet
Hi
Installed a new toilet, and I have a slight leak on one of the through bolts which holds the pan and cistern together.
There is a rubber seal on the cistern side, and I'd like to put something around the hole to try and stop the leak, but the instructions say you shouldn't use waterproof sealant - can someone recommend something that will help to make it watertight without damaging the rubber seal?
