Kenmore gas dryer overheating and shutting down
I have a Kenmore 110.97195120 gas dryer (electronic/propane). Lately, I've found it to overheat and shut down when in the permanent press setting (lowest heat/highest drying). I can set it on knit/delicate, and it seems to work fine. I opened the dryer up and cleaned the little bit of lint I could find, along with cleaning the vent pipe, and nothing seems to change. I have the Part No. 3395267 Rev. B Parts List. It appears a part will need to be replaced. Please help me identify what part to replace. Thank you.
That part # isn't "Googling" well.
What is the Part No. 3395267 part? Thermostat? Hi-limit cutout switch?
As stated, that is the part number of the parts list. I included that, in case there is a revised list of part numbers.
Does anyone have an idea as to the reason the dryer overheats and then shuts off when I have it in the permanent press setting? If you don't have the answer, are you aware of where I can acquire the answer?
