Hello Everyone, A new poster here.
I have an approx. 15 y/o Irritrol controlled system (electronics inside home), I think Richdel 1" solenoid operated zone valves. Until lately, working fine. I have noticed recently sprinklers don't seem to have the volume they used to have. Went thru the zones, cleaned out sediment (on a well) but no help here. At the zone valve I'm working at I can hear the water going thru like they are restricted or only partially open. I attempted to open and close the manual valve on the zone valve thinking maybe something was in that particular valve, no joy. On a whim, I opened the little bleeder valve and all of a sudden, full power to the sprinklers, jet stream of water out of the hole where the bleeder screw came out of. I did this (with the bleeder valve) a couple of times with the same result. I'll have to dig up other valves to try them as the moles have filled my valve box w/ spare dirt. Is it possible that the solenoid is not pulling in all the way, and therefore not allowing the valve to open completely? I don't know if a solenoid can pull in partially, can it? I believe they are sort of "digital" either on or off, pulled in, or pushed closed. I have not checked voltages to this point. No solenoid "clacking" at the valves. Thanks for any input you can provide. SteveA
