Hardwired oven
Portsmouth
I've just purchased a new Bosch oven, I was assured by the sales assistant that it could have a 13amp standard plug fitted. On deliver I found that there is no 3 pin plug inculded (not an issue to wire this up) but it got me worried so I called Bosh who said that they wouldn't recommend fitting it to 13amp. Both the assistant and Bosch customer service went via the 2900kw label on the oven to give conflicting advice.
Who should I believe and what kw is it ok to fit a 13amp fuse to? Any help would be much appreciated.
