Hi all,
I am new here and this is my first post, so thanks in advance for any help.
I have a problem in my lounge on two external facing cavity walls.
When I first purchased my house I noticed the paint work close to the skirting about 1 foot high was blistering, flaky and peeling, I put this down to it being old paint work and maybe some damp in the walls.
Since then I have had the two walls chopped out for electrical work and re-plastered and skimmed, so both fresh walls.
I have also re decorated the entire room, after about 3 months the same problem has occurred in the same place on the same walls and only these walls.
I have noticed that the patio outside is fairly high and may be very close to or level with the DPC.
My thoughts are damp is hitting the walls when it rains etc and this is passing through the brickwork.
so my question is,
1. Is this likely the cause?
2. Can it be cured?
3. Can I seal the external walls to stop water ingress?
4. Can I paint the internal walls with some kind of damp proof paint and then repaint over with my choice of emulsion?
Any help and advice much appreciated.
Pictures included
so my question is,
2. Can it be cured?
Pictures included
