Faced or unfaced attic insulation. Climate zone 3.
I am in climate zone 3. North of the warm-humid line. I am insulating an attic. Should I use faced or unfaced insulation? Unfaced is less than faced, so I'd like to go that way, if possible.
Hi there. If the climate where you are is not humid, then unfaced should be sufficient Due to the lack of moisture in the air.
