- Joined
- Sep 7, 2020
- Messages
- 6
- Reaction score
- 1
- Country
My Glow Worm 18HXI boiler is suffering from way too much cycling - it's either on for about 15 secs and heating up to the set 60 degree temp, whereby it turns off completely, when I think it should modulate. The result is excessive switching of the boiler on and off, and a "slug" of hot water being pumped into the radiators, which because of this don't reach the required temp. The pump is working fine, and all controls (other than the boiler) are working correctly. I just can't get the boiler to modulate on low flame, which would see the radiators hot all the way through, instead of "slugs" of heated water reaching them. The boiler was serviced last week, and the guy said this cycling was normal, but I don't remember it being this way, and I'm fearful of this constant cycling ruining some parts of the system through over use. What I can remember is the boiler running on low flame once the water was up to temp, but it doesn't do this any more, just on then off. Anyone any ideas on how I can fix this please?
