EP 2002 Controller issue
Hi all
Just moved into rented house, with a very old CH and HW system governed by an EP 2002 timer/controller
Got it set up to check functionality before the cold weather sets in, and all works fine.
However, noticed that when the thermostat is set right down, or the boiler is in between active settings, or the boiler internal mains switch is off, something is still running although the boiler is cool to the touch.
I've read some posts on this site, and figure it could be the pump running continuously if the water temperature doesn't reach the thermo setting?
How do you reset the temp, and where is this thermostat?
Sorry, but green around the gills here...!!!
