Beam size advice
So trying to avoid the cost of a structural engineer. I am opening a 12' load bearing wall between two rooms. My house has web floor joists. The beam will hold one floor and a roof above. Below is the garage with a steel beam and has a steel pole in the center. I am trying to find the least expensive way to build the beam. I was thinking of using 2 2x10x12 with plywood in between or 3 2x10x12s. Currently it is only framed with 2x4s on 24" centers. Any advice would be appreciated.
Beam size 8
Size (width) concrete beam 2
What size beam to span 6 feet... 11
Beam Size ? 5
Odd steel beam section size 4
Size of wood beams? Corrugated roof? 11
Steel beam size 5
determining beam size 1
