Aluminum Window frame slide mechanism
California
The house was built in 1980 and has a set of Windows with Aluminum frames.
At the bottom corner of each frame is a small plastic piece ( see picture) that seems to be used for sliding on the metal rail. I have a few that have one side broken with results that the windows do not slide very well and are tilted in the frame.
Where can I get the replacement slides from or use some other substitute?
The plastic piece is held into the frame with the second Philips Head screw on the RHS. and sits on the metal rail.
Thanks for your time and advice.
Australia
Hi Everyone!
Doors and windows are the important elements for the beauty of any house and if this is not made good material and giving not a good look then your house also looks not good. So, when you want to install these doors and windows in your home you should choose a professional company for this. Because these elements should long-lasting and you are not able to change it daily. So, Mir Windows is a good option for this purpose and you will really happy with their services at affordable prices.
