Hi there, I am a student at University and am currently working through my final year project. This involves cutting a small trench on a concrete driveway in which a Polyurethane cable will sit in. The trench needs to be 1 inch wide and 5mm deep. Im not too sure what is the best way to cut this. Methods I have considered are:
Using a grinder with a diamond blade, though i'm not sure that it would be easy to cut a straight line of constant depth with this.
Use a circular saw with a diamond blade, on top of sawkart, which makes it portable and easier to cut a straight line.
I know that I have to used a diamond blade when it comes to concrete, but are there diamond blades thick enough to cut 1 inch wide? I have found this blade that would be perfect, but is this able to be used on a circular saw even though it is meant for a grinder? Sorry I cant post photos or links to the grinder wheel or sawkart, I dont have enough posts!
Any information you can give me to help would be greatly appreciated.
Andy
Andy
