Hello forum! First time post here.
I am a fairly handy amateur carpenter and had a builder come around to replace the floor in my shed, which was very rotted with wood worm (it was the removal that I couldn't do, as the rot creaped me out).
While his construction method was good, he made a very very bad mistake. The previous beams under the floor extended under the walls. He removed these, but the new beams ended about half a cm before the walls, creating a floating floor, so that he could wrap waterproof lining all the way around the edges.
So, obviously, the shed is now slowly sinking, as there's nothing holding up the walls except the facia. There's about a 5cm drop so far.
Underneath the new floor he installed is a basic concrete slab under the whole shed, which appears very level.
I intend to take the new floor out, fix the walls, and put the floor back in, and here's where I need the advice:
I need some hind of technique or tool to prop the walls up a bit at a time and then something to rest the walls back down. Presumably I can just stack bricks?
Anyone have any advise as to:
A. If bricks are the best thing to use or
B. How on earth I can prop the shed up to begin with, to fit something underneath it?
Thanks so much in advance for your help!
Kindest,
Max
Kindest,
Max
