Johnny Boy
Hi
I've installed a new kitchen sink and have put supplemental bonding from the incoming cold water
pipe across to the hot water pipe and also to the sink. The regs don't require this but I can
see no harm in it, and it reinstates the position before the works on the kitchen. I wonder why
this was dropped from the regs?
I also noted that the main bonding from the water pipe to the block adjacent the CU is 6mm.sq
not the 10mm.sq that the 16th ed. specifies. I condsider that there's no need to uprate this to
10mm.sq since the regs are not retrospective. Also it would be almost impossible physically
without taking the wire round the outside of the house! Again, I wonder what was the rationale
for the change?
Finally, I know it's been done a while back on previous threads but what 's the view re 2.5mm.sq
unfused spurs from 2.5mm.sq ring mains (Type B CB at 32A). My personal view is that it's not
acceptable on grounds of cable rating - but it used to be allowed. Anyone know why this
changed?
Regards
Jx
for the change?
changed?
Regards
Jx
