Richard A Downing
I want to wire up some 12V downlighters to the transformer. I cannot
find out what the correct wire is to use for this. The easiest thing
to use would be 1mm T&G. I'm thinking:
35W bulb at 12Volts = 2.91 amps. 3 bulbs on the circuit, so call it 9
amps. 1mm T&G clipped direct (ref method 1) in the roof void allows
15A. So that's OK.
Have I got this right, or is there a special cable that I should use
for this?
R.
Thanks in advance.
15A. So that's OK.
for this?
R.
Thanks in advance.
