Wife drilled into PVC drain pipe
JJ
Usenet Archive
I just discovered that a few years ago, my wife drilled into the vertical drain pipe (Sch. 40) coming down from our upstairs bathroom.
Apparently, she tried hanging a toilet paper holder in the 1st floor powder room and had trouble geting the screw in, so she patched the hole in the drywall and moved it over several inches.
I noticed a slight dampness around the patch and cut it open and found the hole in the pipe. The damage wasn't too bad - a few inch square piece of drywall over a few years of the hole being there, so it can't be leaking much.
Anyway, is there a way to fix this hole without cutting out the section of the pipe and coupling in a new piece? Doing that would require removing much more drywall, which I don't want to do if I don't have to.
Is there anything that can be used to fill the hole or wrap the pipe?
Paul O.
Usenet Archive
If it is just a drain pipe with no pressure in it, I think I would try to force some silicone sealant into the hole.
SteveB
Usenet Archive
In the garden section, they make PVC repair kits. They consist of two pieces that fit over the pipe, and click together. DON'T forget to put some glue on there first. They work great.
Steve
Edwin Pawlowski
Usenet Archive
Probably a dozen ways that will work. How big is the hole? If it is a very small hole, a short screw with some sealer will do. Put a rubber washer under the screw head, spread some silicone adhesive and screw it in. Don't use a long screw as you don't want paper catching on it as it passes inside the pipe.
Cut a piece of a PVC connector that is the same size as used on the pipe. This will have the same curve and fit over top snugly. Using the proper PVC pipe adhesive, glue the patch over top.
George E. Cawthon
Usenet Archive
Sure,if the hole was drilled on only one wall,
i.e., if the drill didn't go completely through
the pipe. Simplest way is insert a screw slightly
larger than the drilled hole and tighten the
screw. Use a screw for metal, preferably a brass
or stainless steel screw slightly longer than the
thickness of the PVC wall.
BocesLib
Usenet Archive
I second the epoxy solution. This guys pipe is a drain pipe. You wouldnt normally want anything going into the inner wall of the pipe because something can get hung up on it.
Tom
CL (dnoyeB) Gilbert
Usenet Archive
Tom
Yep, though Im not a plumber I would surmise you dont want anything sticking into the pipe that a snake might get caught on or agrivate in case its snaked sometime in the far future.
Goedjn
Usenet Archive
True but its a vertical section, so it should be fairly forgiving. YOu don't want a half-inch of screw sticking into it, but a small bump shouldn't be a problem.
Art Todesco
Usenet Archive
After reading all the replies on this
topic, here's mine. I'd use
liquid nails. Years ago I had a problem
where the plasitic pipe
connects to the cast iron connection at
the basement floor.
When the sewers back up, it would ooz
through the yocum (sp?).
I cleaned the area with a wire-wheel and
built up a connection
of liquid nails. It's still tight today
after some 10-15 years.
G Henslee
Usenet Archive
Be glad it wasn't your skull, in your sleep.
Chris Lewis
Usenet Archive
Assuming your pipe is standard ABS DWV, I'd personally fabricate a rough plug out of some ABS scrap, and jam it into the hole liberally greased with ABS glue.
It'll take at least half a day to completely set, but this is probably the most rugged repair, because you're essentially welding the hole shut. Or, "reconstructing the ABS pipe" if you prefer to look at it that way.
PVC glue won't work on ABS. Yes, you can glue PVC to ABS using "PVC-ABS" glue, but why bother? Pure ABS-ABS is better.
Epoxy or various other glues will often work (given suitable prep), but not nearly as well as ABS solvent weld.
Reconstructing ABS using ABS scraps and ABS glue works remarkably well.
I had a electric blower housing case shatter when the impeller came apart at speed. The blower case was 100% ABS. It was easy to piece it back together using ABS glue (and a few scraps), and now you can't tell. It's just as strong as originally.
MattMika
Usenet Archive
Right before I bought my first home I had installed an R/O filter system in my apartment. For the waste water line I had to drill a hole in the drain pipe. When I removed the R/O unit I simply threaded a short nylon bolt into the hole. Worked like a charm. It was alot easier than replacing the drain pipe....
Matt
Calvin Henry-Cotnam
Usenet Archive
Chris Lewis said...
The OP's subject line says "PVC", so the ABS suggestions will not work.
What colour is the pipe -- white, black, or something else?
Where I am (Toronto), we cannot use PVC for DWV, so the only plastic DWV pipe used is ABS and that is black (ABS, the plastic, can be made in just about any colour, but the DWV pipe is black).
We can, and usually do, use PVC for the drains from the house to the sewer system, but the PVC-to-ABS coupling is below the basement floor. Here, PVC used for sanitary drains must be coloured and is usually green. White PVC can only be used on storm sewer connections (in our municipality, only the weeping tile can connect to it).
Or a PVC solvent weld, if the pipe is PVC.
TPutmann
Usenet Archive
Dude,
Your wife is stupid Stupid STUPID !!!!
Get a divorce.
After that,
Then clean the hole real well and coat it with JB Weld
Next, take a Fernco coupling and slit it down one side (with the clamps off of it). Slip it around the pipe and install the clamps. You'll have to work the clamp bands into the threads of the clamp, which can be a little tough to do inside the wall.
Be sure the split in the fernco is AWAY from the hole and the JB Weld is still wet.
I would NOT use the quick drying JB Weld. It will take a while to get the clamps on, and the stuff will dry to fast.
lisac
