What/Who is Scary Sharp
Peter Ashby
Andy Wade said:
Peter Ashby" wrote in message
So the advantage of this method compared to 'normal' oilstone sharpening is
what exactly? The wet & dry paper is used with water, with oil, or dry?
I use it dry, though you can use water. The advantages are several,
firstly you get a wide range of grits for very little money, using a
glass backer removes the need to flatten a stone periodically, wide
plane blades can be honed with long figure eight strokes and finally,
compared to a wheel there is no chance of overheating the blade unless
you are superman.
Disadvantages: grinding, for eg removing a nick, takes a while. However
I have made two skew chisels from straights (2 cherries) using scary
sharp.
Peter
jagga009
