What size hole to drill for 32mm waste ?
Jim
I am installing a new basin and need to take the waste outside (32mm) what
size core drill do I need to get for this ??? 30mm 32mm 38mm
I presume that it will be 38mm but just want to make sure
Al
Go with bigger than 32mm.
BigWallop
I'd say it depends on how much movement you want to gain in your plumbing.
One method of disguising a large hole for pipework is with another smaller
wood panel screwed on top of the first. The actual hole behind can be quiet
large, but when you cut the hole in the face panel, you make it fit neat
around your pipework.
Cut the face panel in half, right through the middle of the hole for the
pipe, then screw the face panel to the back, joining the two halves
perfectly back together. This method also has the advantage of allowing
access to the pipework in the future, without having to rip everything out
if, luck forbid, you suspect leaks or other damage.
Martin
Wow - PillowBag is back.
Welcome, mate.
Where've you been...? It's been ages...
Joe
Right so when you join up the board....... dam it don't meet in the middle.
Should have made an allowance for the saw cut, oops.
Joe
