What is this called
Jim
Some kind on insulation has been put in my m8 flat and i could do with
it myself for something but i have google "draft excluder" "draft
excluder rubber", "windows draft excluder" and never come across the
right stuff check b&q, home base screw-fix even fleabay and nothing, so
i presume i'm not using the right search term, i only need about 7-8
feet of it
link for image is here
http://img526.imageshack.us/img526/1249/pc081826.jpg
Jim
W
Woody
do with it myself for something but i have google "draft
excluder" "draft excluder rubber", "windows draft excluder" and
never come across the right stuff check b&q, home base
screw-fix even fleabay and nothing, so i presume i'm not using
the right search term, i only need about 7-8 feet of it
Jim
It is just a simple draught excluder. Anything you find in a diy
shed will do just as well.
Incidently it is bad protocol to use text sortforms on a usenet
group, i.e. mate not m8.
Jim
Yea i know not to use m8 trouble was i had just got of the phone from
texting my mate and it just followed on here, soz oops sorry ;-)
Jim
Jim
B&Q he said? Something like this
<http://www.diy.com/nav/build/insula...-Seal-10mm-x-7m-White-11607768?skuId=12118474>
otherwise accessed by
<http://preview.tinyurl.com/c5nvdsd>
will probably do it. And doesn't involve drilling holes in the window
frame - which if you are renting you should check with your landlord.
Andy
Thanks for the reply Andy, no that will not do for my needs, it's to be
used with a set of balcony doors where the wind comes between the 2
doors, i have no issues with nailing it in place as new double glazing
is going in next summer, it seems the best i can get is the stuff that
has brush effect on it that normally goes on the bottom of the doors
which i'm sure is better then nothing but would look well out of place.
Jim
jagga009
