What is head?
Discussion in 'UK DIY' started by Charles Middleton, Nov 11, 2004.
  1. What is head when talking about water systems in a house?
    How does it relate to hot/cold water and water for radiators?
    Thanks in advance,
    CM.
  2. Charles Middleton
    IMM Guest
    "Charles Middleton" <> wrote in message
    > Thanks in advance,
    Simply head equals pressure. In a house with tank in the loft the presure
    is "x" head. The head refferes to the height of the tank from its water
    line. The higher the more the pressure. 1 bar is approx 30 foot. If the
    tank is 30 foot above you the pressure where you are will be 1 bar. That is
    why in 3 story house when the tank is in the loft, on the 4 th floor, the
    pressure in the basement is high and on the top floor very low.
    A man I know, to increse the pressure on his shower installed another large
    100 gallon water tank in the loft. He was confued at why the pressure had
    stayed the same.
    So if you have a 4 floor house and the pump and boiler in the basement the
    pump may not reach the top floor radiators. The more bends and elbows in a
    pipe, the more the pressure is reduced, so a punmp has to be sized with the
    pipe run taken into acciount. Lots of elbows and the 20 foot head pump may
    only raise water 15 foot.
    A pump may be rated at 20 foot head. If a 40 foot clear plastic tube is
    attached to the outlet of the pump and it runs up directly vertical, if the
    pump pumps water from the same level the pump is on, the water should rise
    up 20 foot in the plastic tube.
    You must have heard the term "a head (pressure) of steam" on films, when the
    train driver or ships engineer waits for the steam pressure to build up to
    move the ship or train. Or the fireman shovels coal in like hell to keep
    "the head up" to keep up the speed.
    IMM, Nov 11, 2004
  3. Charles Middleton
    Set Square Guest
    > Thanks in advance,
    > CM.
    It's a measure of static pressure expressed in terms of the pressure which
    will exist at the bottom of a vertical column of water of specified height.
    For example, the head of water at your kitchen tap (for a stored hot water
    system) may be about 15 feet (roughly 0.5 bar in pressure terms) - being the
    vertical distance of the surface level of the water in the header tank above
    the tap.
    The static head of water in your central heating system is measured in the
    same way (assuming a vented system with a small F&E tank in the attic). The
    static head in the downstairs rads will be greater than that in the upstairs
    rads due to their relative vertical positions. In a pumped central heating
    system there will, of course, be a dynamic pressure which is exerted by the
    pump and superimposed on the static pressures.
    Hope this makes sense!
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Nov 11, 2004
  4. Charles Middleton
    Set Square Guest
    > basement the pump may not reach the top floor radiators.
    That might be true if the pump was picking up its water from an
    open-to-atmosphere trough in the basement. But, of course, it isn't! It's
    being fed with a static head of water commensurate with the 4-floor house -
    and only has to generate sufficient *dynamic* pressure to overcome the flow
    losses.
    Back to your Physics text book, Mr IMM - if you ever had one!
    Cheers,
    Set Square
    ______
  5. In article <>,
    > the pump may not reach the top floor radiators. The more bends and
    > elbows in a pipe, the more the pressure is reduced, so a punmp has to be
    > sized with the pipe run taken into acciount. Lots of elbows and the 20
    > foot head pump may only raise water 15 foot.
    The *pressure* is reduced by bends and elbows, is it?
    Remind me again of what you claim to earn a living at?
    *'Progress' and 'Change' are not synonyms.
    Dave Plowman London SW
    Dave Plowman (News), Nov 11, 2004
  6. Charles Middleton
    BigWallop Guest
    > Thanks in advance,
    > CM.
    The term Head, when used in plumbing, is the height you have from a static
    feed tank which is above all other appliances. So, the higher the head of
    water, the more pressure you get in the pipes to move the water below it.
    Version: 6.0.792 / Virus Database: 536 - Release Date: 09/11/04
    BigWallop, Nov 11, 2004
  7. In article <>,
    "IMM" <> writes:
    Hum, you have got a couple of different concepts mixed up here.
    Yes, but the central heating pump is responsible for circulating
    the water in the system, not keeping the upstairs radiators filled
    up. Central heating pump only has to overcome the dynamic pressure
    drop of the system at the operating flow rate which is normally of
    the order of a few feet of head, and is not related to the hight
    of the header tank or the fill pressure of a sealed system. A
    central heating pump won't normally generate anything like the
    head required to pump water from the ground floor to a loft
    header tank or even upstairs radiators, and doesn't need to.
    Andrew Gabriel
    Andrew Gabriel, Nov 11, 2004
  8. In article <cn0l0s$act$>,
    Andrew Gabriel <> wrote:
    > A
    I'm trying to remember my basic physics about the maximum head an impeller
    pump can generate? I'd think it unlikely to be more than 1 bar?
    *Two many clicks spoil the browse *
  9. In article <>,
    "Dave Plowman (News)" <> writes:
    >> A
    I can't think of a reason for a limit. It basically uses
    centrifugal force at the outer edge of a volume of spinning
    water, and if you make the diameter larger or the angular
    velocity higher, the pressure should increase. Maybe there's
    some factor I'm overlooking (cavitation)? Of course, there's
    a limit to what a 3" diameter impeller on a 100W motor in a
    central heating pump can achieve. I just looked up the spec
    of one typical heating pump, and it's 0.5m head.
    Andrew Gabriel
  10. Charles Middleton
    IMM Guest
    "Set Square" <> wrote in message
    house -
    flow
    > losses.
    You need to know more about heating and the many plumbers who have had to
    replace a pump with a more powerful version because the tops rads only get
    warm, or not at all
    IMM, Nov 11, 2004
  11. Charles Middleton
    IMM Guest
    "Dave Plowman (News)" <> wrote in message
    > In article <>,
    What the f**k do you know about heating? err, err, er...nothing.
    Not twiddling a knob.
    IMM, Nov 11, 2004
    #11
  12. Charles Middleton
    Ed Sirett Guest
    > losses.
    Thanks. Whilst he started well when talking about the roof tanks, the plot
    got lost on CH circulators.
    IMM has some agreement with higher powers than I deal with that exempt him
    from the known laws nature.
    Ed Sirett, Nov 11, 2004
    #12
  13. Charles Middleton
    IMM Guest
    "Andrew Gabriel" <> wrote in message
    news:cn0l0s$act$...
    > In article <>,
    > "IMM" <> writes:
    the
    in a
    the
    may
    the
    rise
    Depends. A pump will have "x" head on it inlet and oulet, in theory
    balanaced out. In practice the the boiler gets in the way and a lot of
    piping. From what you say a pump need only just move a water a little. If
    the restriction is high on the inlet, the suction side you may find there
    will be little flow, if any, at the far end.
    IMM, Nov 11, 2004
    #13
  14. In article <>,
    > to replace a pump with a more powerful version because the tops rads
    > only get warm, or not at all
    Likely because they're the furthest from the pump and the longer the
    pipework, the greater the resistance to the flow.
    *If you don't like the news, go out and make some.
    #14
  15. In article <>,
    Obviously rather more than you, though, then?
    You'd not last five minutes at it. It's something that requires skill. Not
    just quoting reams from websites and brochures without understanding a
    word of it.
    *What do little birdies see when they get knocked unconscious? *
    #15
  16. Charles Middleton
    Set Square Guest
    > little. If the restriction is high on the inlet, the suction side
    > you may find there will be little flow, if any, at the far end.
    The important point - which you need to get into *your* head - is that this
    has nothing to do with *static* head (which is self-cancelling in a
    circulating system) - but is simply a function of circuit resistance.
    If you took all the pipework in your notional 4-storey house, and laid it
    out in one *horizontal* plane, you would have exactly the same relationship
    between pump dynamic pressure and cricuit flow as you had with the original
    vertical pipework.
    Cheers,
    Set Square
    ______
    Set Square, Nov 12, 2004
    #16
  17. Charles Middleton
    IMM Guest
    this
    The pump head overcomes that. Duh!
    IMM, Nov 12, 2004
    #17
  18. Charles Middleton
    IMM Guest
    > In article <>,
    That is a question. Answer NO.
    Stop commenting on fields you know sweet FA about.
    Keep twiddling the knob.
    IMM, Nov 12, 2004
    #18
  19. Charles Middleton
    IMM Guest
    > In article <>,
    Go way....you don't say! Duh!
    IMM, Nov 12, 2004
    #19
  20. Charles Middleton
    Steve Firth Guest
    > word of it.
    A palpable hit sir!
    "They that can give up essential liberty to obtain a little
    temporary safety deserve neither liberty nor safety."
    -- Benjamin Franklin, 1759
    Steve Firth, Nov 12, 2004
    #20
  1. [UK]CuteSpunkyLad
    Help! Insufficient head for modern taps grrrrr :@
    [UK]CuteSpunkyLad, Sep 2, 2003, in forum: UK DIY
    602
    BillR
    Sep 2, 2003
  2. John Stumbles
    Re: Securing shower arm/head to wall
    John Stumbles, Oct 29, 2003, in forum: Misc DIY
    2,226
    John Stumbles
    Oct 29, 2003
  3. PoP
    Shower head
    PoP, Dec 20, 2003, in forum: Misc DIY
    8
    588
  4. Ben Blaukopf
    Monobloc mixer leaking from head
    Ben Blaukopf, Jan 5, 2004, in forum: UK DIY
    444
    Ben Blaukopf
    Jan 5, 2004
  5. Harry Bloomfield
    Shower head jet clogs!
    Harry Bloomfield, Jan 14, 2004, in forum: Misc DIY
    935
    |^eekaye
    Jan 15, 2004
  6. Robert11
    711
    wayne
    Jul 4, 2005
  7. m Ransley
    535
    Mikey
    Aug 1, 2006
  8. Replies:
    8
    664
