Main Entry: 2enamel
Function: noun
1 : a usually opaque vitreous composition applied by fusion to the surface of metal, glass, or pottery 2 : a surface or outer covering that resembles enamel 3 a : something that is enameled b : ENAMELWARE 4 : a cosmetic intended to give a smooth or glossy appearance 5 : a hard calcareous substance that forms a thin layer capping the teeth -- see TOOTH illustration 6 : a paint that flows out to a smooth coat when applied and that dries with a glossy appearance
Main Entry: la·tex
Pronunciation: 'lA-"teks
Function: noun
Inflected Form(s): plural la·ti·ces /'lA-t&-"sEz, 'la-/; or la·tex·es
Etymology: New Latin latic-, latex, from Latin, fluid
1 : a milky usually white fluid that is produced by cells of various seed plants (as of the milkweed, spurge, and poppy families) and is the source of rubber, gutta-percha, chicle, and balata 2 : a water emulsion of a synthetic rubber or plastic obtained by polymerization and used especially in coatings (as paint) and adhesives
Main Entry: 2acrylic
Function: noun
1 a : ACRYLIC RESIN b : a paint in which the vehicle is an acrylic resin c :
a painting done in an acrylic resin
2 : ACRYLIC FIBER
Main Entry: acrylic resin
Function: noun
: a glassy thermoplastic made by polymerizing acrylic or methacrylic acid or a derivative of either and used for cast and molded parts or as coatings and adhesives
Main Entry: acrylic acid
Function: noun
: an unsaturated liquid acid C3H4O2 that polymerizes readily to form useful products (as constituents for varnishes and lacquers)
