Weil-McLain on last legs...keep replacing parts or whole new system?
alaskarockgirl
Usenet Archive
Hello,
Need some advice. Purchase a 1250 sq ft condo in July. It has a Weil- McLain AHE boiler Series 4 that was installed in 1994 that provides baseboard hot water heat and assists a hot water maker/holding tank. So far, this fall, I've replaced the igniter, the pressure switch, and oiled the fan (that equals 3 service calls). And now that it's January and -15 at night, I've hit a wall.
The boiler is still not operating properly. It fires occasionally, but though it will heat correctly for 20 minutes or so, the flame will turn off and the boiler will continue to run and circulate water until the external temperature gauge on the boiler drops to 70 degrees, or lower, before it will refire. Even though both thermostats and the water tank are calling for hot water. And only sometimes will it refire. Usually I have to flip the switch to the boiler, let it sit for 10 minutes, then turn it back on to get it to fire, warm up, heat the house (kind of) and then it proceeds to do the same trick.
Needless to say my gas bill and electric bill keep going up. And my place is not warm at all. And to make matters worse, my hot water maker (Amtrol) holding tank developed a leak yesterday in the wall of the tank, so that needs replacing.
So, do I: 1. replace the water tank and keep changing out parts on the boiler? 2: Replace the boiler and water tank? or 3: Invest in a boiler that doesn't require a separate water holding tank?
Thanks for any advice. This is one of the joys of homeownership, I realize, but I still would like a warm house and a hot shower anytime I want!
Cheers!
The King
Usenet Archive
Hello,
Cheers!
Take your Alaskan welfare check and help some poor hvac guy stay in business by buying a new boiler.
Fartikus
Usenet Archive
So the Alaskan HVAC guy doesn't get his welfare check too? poor guy.
Perry (archive)
Usenet Archive
Perry had written this in response to
http://www.thestuccocompany.com/hvac/Re-Weil-McLain-on-last-legs-keep-replacing-parts-or-whole-36326-.htm :
Fartikus wrote:
"The King" wrote in
message
> On Mon, 5 Jan 2009 15:53:40 -0800 (PST),
> wrote:
>>Hello,
>> Weil-
>> provides
Get you a Noritz instantanious Water Heater. No Tank, a lot more Eff.
Delivered via http://www.thestuccocompany.com/
Building Construction and Maintenance Forum
Web and RSS access to your favorite newsgroup -
alt.hvac - 27760 messages and counting!
YOUNG GUN
Usenet Archive
YOUNG GUN had written this in response to
http://www.thestuccocompany.com/hvac/Re-Weil-McLain-on-last-legs-keep-replacing-parts-or-whole-36542-.htm :
I prefer the munchkin contender.
Fartikus wrote:
> "The King" wrote in
> message
>> wrote:
>>>Hello,
>>> has a
>>> Weil-
> guy.
alt.hvac - 28060 messages and counting!
lisac
