Waste drainage problem
BillR
alex said:
I have just fitted a glass bowl basin in my bathroom, it has a pop-up
waste and no overflow. I have problems getting the water to flow
away, I usually have to operate the waste several times in quick
succession, it seems as if there is an airlock.
or insuficient slope on the wate pipe..
Could this be because of no overflow to admit air?
That isn't the job of an overflow.
If so, is it possible to fit some sort of device to admit air?
you can get a bottle trap that is meant for syphoning problems, Marley about
5 quid in B&Q.
I doubt it will help your problem though
Many thanks in anticipation.
maybe a fundemental design problem with the basin.
Often the fancy looking items are a bit impractical like one toilet I fitted
not too long ago, looks great but blocks very easily..
Chris J Dixon
That is what worries me about choosing a new one, as I am in the
process of doing. I'm sure they all meet (somebody's) standards,
but that doesn't necessarily mean that they work well in real
life.
Any specific pointers?
Chris
Chris J Dixon
alex said:
I have just fitted a glass bowl basin in my bathroom, it has a pop-up waste
and no overflow.
What is the regulatory position about sink & bath overflows?
IIRC it used to be down to local requirements.
Can the bath pop-up waste fittings that seem to be popular now be
used without the overflow connection?
Chris
The Natural Philosopher
life.
Anything will work with a saniflo pump :)
I looked in my 2 year old regs copy, and the matters addressed are pipe
diamter (32mm) and use of traps only. No mention is made of requirements
for overflow.
I have left many a bath/sink/basin running and flooded the floor, even
equipped with overflow. No overflow I have ever used can cope with mains
pressure water at full crack on even a basin tap.
My conclusion is they are almost a waste of time: The only time they do
something useful is when you lower yourself gently into the bath, you
don't have to pull the plug out to drop the water level if you do it
slow enough for the overflow to cope.
Chris J Dixon
Let's not go there :-(
Anyway, surely the s******w won't actually suck out of the pan,
it simply pumps away (most of) what is presented to it
Chris
Chris J Dixon
for overflow.
Alternatively, if you don't fit one (and you don't make waves)
you can have another 50 mm of water to soak in.
When bath capacities are stated, what are the standards for
measurement? ISTR an allowance of 70 litres for displacement.
Chris
alex
and no overflow. I have problems getting the water to flow away, I usually
have to operate the waste several times in quick succession, it seems as if
