vinyl flooring on our sundeck
Ninip
Usenet Archive
Hi all
I hope someone can give me some help.
We have a sundeck over our carport.
We replaced the plywood subfloor and are going to hire contractor to lay rolls of vinyl. But we are confused about thickness, so many different opinions from contractors. 40 mil, 55 mil, 60 mil. Also fabric backed verus plastic backed. Can anyone give us their experience. Also does it tear easily from patio furniture? And does the plywood have to be bone dry for them to lay it? Thanks for all your help in advance.
SQLit
Usenet Archive
Ninip said:
Hi all
Vinyal outside? exposed to the sun and weather... Sounds like an accident waiting to happen. Is the product even rated to be outside? Thicker would be better in my mind. Fabric backing and water sounds......... dumb. If you have metal furnature then there is always a risk of injuring the floor. You could put the plastic sliders on the feet of the furnature. Again I do not know if they will hold up to the elements.
Ninip
Usenet Archive
Hi
I think I did not explain myself well enough.
This is not kitchen vinyl, but sundeck flooring. Our sundeck is not covered but instead of fiberglass coating (which is more expensive) here in Canada the other option is called vinyl decking. It is a waterproof membrane. Any thoughts?
lisac
