Very worrying burning smell from vacuum cleaner (Miele)
ChrisHollandisback
So I bought a great vacuum cleaner from selfridges .. has been working
fine
...until today
Starting smelling a very worrying burning smell (like plastic on fire)
... last night... I sucked a fly up into it... it's a 2200W hoover... I
usually use RAID spray to zap any flies that piss me off... but it was
entertaining to suck it up...
Erm... should I take it back to the shop?
Maybe I sucked up a big metal object or something? i dunno
X
xena
Back in the summer, I was using the hose on my Dyson DC01 to suck the flies
from around my horse's face and eyes. Stupid flies didn't learn and I ended
up with many hundreds buzzing around the clear plastic bin. Horse loved it.
:eek:)
Sorry, doesn't answer your question...
mike
(e-mail address removed) wrote in
fine
I had a Miele; it went on for years.
Then it blew up.
Yes, blew up.
I thought you'd like to know
mike
The3rd Earl Of Derby
fine
..until today
Do take it back.
Oh,and what does a 2200W Hoover fly look like?
The Natural Philosopher
fine
..until today
Overheating motor. Bag full/filters clogged. Remove all and run..if it
revs a LOT higher than when put back together you have a problem.
No. More like lots of fine dust.
Phil L
fine
..until today
This wil probably be the belt melting, meaning that the belt is turning but
the steel part which should spin (via the belt) is jammed, probably with
something, rarely nothing, but it's best to have a look.
I doubt a fly could have blocked it, unless it was sat in a box of LEGO at
the time.
That depends on how long you've had it, if it's less than a year, yes, if
it's more than a year, don't bother as they'll charge you for any work which
needs doing which you could do yourself in ten minutes.
Neither do we....did you hear a sort of metallic, clangy-bangy screeching
noise fill the room, like the sound you get when you try to drill through a
steel girder with a masonry bit? - if you didn't then it's unlikely you went
over a big metal object.
O
Owain
fine
...until today
I don't think the fly was to blame.
Possibly. I gave up using my last vacuum cleaner because the switch-on
sparks started getting continuous and the whole casing was lighting up
like something out of Frankenstein's laboratory.
I'd suggest taking it outside where there's nothing flammable round and
running it for a while and seeing what happens.
If it turns into a melty lump, take it back. It'll be fun to see them
try to claim catching fire isn't covered by the guarantee.
Owain
Staffbull
The3rd said:
Do take it back.
"Oh,and what does a 2200W Hoover fly look like?"
ROFL !!!
Douglas de Lacey
Might be as simple as a stuck brush bar if it's an upright. in which
case it's melting belt. Can we have some more details, OP?
Douglas de Lacey
N
Newshound
A bit off at a tangent, but a few years ago one of the vac's went bang and
tripped the RCD when I was at work and the wife was using it. Because she
really doesn't like electrical bangs she unplugged it and put it out on the
patio whereas I would have put it in the workshop. Just as well really
because a couple of hours later she looked out of the window to see it
blazing merrily, and she called out the local firemen. The added amusement
was it had started snowing by then and having kicked it well out of the way
of the house they had to fill in their form, and where they had to fill in
"Method used to extinguish fire" they wrote "snowballs".
The serious point is that most electrical stuff is self extinguishing for
your standard "frayed cord inside" type of fault, but vacuum cleaners with
their bag of fine combustible dust need to be treated with a bit more care.
If I had put it in the workshop I don't suppose we would have known about it
until it had reached the thinners, paint, propane cylinders.......
ChrisHollandisback
Then it blew up.
Yes, blew up.
mike
Mike
ChrisHollandisback
I've had it for a few weeks! It cost £150 or something.
My mum had her Basil Hoover for 23 year and she was just using it today and 2 minutes after using it, it made two loud bang noises and then it started to make a bonfire smell. Does anyone know what this could mean ??, I'd appreciate your help.
Yarm, UK
Could be one of two other things. Usually, there is a capacitor inside, across the mains on vacuum cleaners. If it is a cheap capacitor, they have been known to go bang or let out 'magic smoke'. It stinks when it does go. The other thing it could be happened to ours a couple of months back. My wife sheds hair because of the meds she is taking. It is long strands of hair and wraps around the rotary brush and end bearings. The hair smouldered after really building up, causing quite a smell. I now dismantle and clean the brush every couple of weeks.
Colin
