Two questions about security light above the garage door
deja_bhoot2000
Usenet Archive
My wife bought a "security light" at Costco, to be installed above the garage door, below the eve of the roof. It's a basic model, with two bulbs, probably no more than $50. The unit looks identical to what is shown at the following URL (no ads or popups, or dancing monkeys, so feel free to click.)
http://www.cornerhardware.com/howto/ht015.html
We did not previously have an exterior light above the garage door, so there was no electrical outlet. Inside the garage, there was an available outlet, about 5 feet away from the door. So, I bought a cheap extension cord, plugged the pronged end in the outlet. I put the extension cord through the hole, cut and threw away the end of the cord, and attached the the hot and neutral wires to the corresponding wires on the security light. It works, but I have two questions / concerns:
Q1. I was able to run only 2 wires from the outlet, so there is no grounding wire running from outlet to the "circular plate covering the hole in the wall", as shown in the picture at the URL listed above.
Is this a complete no-no? As I asking for trouble? Or is it OK? I have some small appliances (desk fan, table lamp, etc.) that use cords with only two wire -- no grounding wire.
Also, the extension cord from outlet to the security light is only 5 feet, well insulated, and the security light is mounted well above the ground. There are no metal parts near it (garage door is an ancient, 30 year old, single panel, wood door).
Q2. When security light is activated, it suffers from flickering IF the garage door is fully open. If the garage door is closed at least 20% or so, i.e., the door panel is angled at least 20 to 30 degrees, the flickering stops (0 degree means fully open; 90 degrees mans fully closed)
This is again due to reflection from the garage door (painted white). I treat this flickering as a feature (reminding us to close the garage door), but my father thinks of this as a bug. Any suggestions to avoid flickering? (Sort of upgrading garage door to a new, sectional kind).
Thanks a lot.
Bhoot Nath
Roger Taylor
Usenet Archive
My wife bought a "security light" at Costco, to be installed above the garage door, below the eve of the roof. It's a basic model, with two bulbs, probably no more than $50.> We did not previously have an exterior light above the garage door, so there was no electrical outlet. Inside the garage, there was an available outlet, about 5 feet away from the door. So, I bought a cheap extension cord, plugged the pronged end in the outlet.
This is no way to hook up an exterior light, period. Not safe, with rain and no ground, not in code, and not weatherproof. You need to run a proper behind-the-wall Romex or conduit to the site, install a junction box, and do it right, with groundwire weatherproof gasket, and all. Cheap light units may flicker when the sun sensor cannot decide what light level is outside, or the level adjustment needs twiddling.. Home Depot sells a 50-70 buck motion sensor light by Heath or Stanley called the JourneyMan, with lifetime unconditional guarantee. Thier sun sensor seems pretty robust, as I have had three units for six years, and seem to work flawlessly, in spite of being imports. Inexpensive security lights tend to have early failures in my experience, but both your door reflectivity and the way it is hooked up without a ground may be inducing flickering.
Jeff Wisnia
Usenet Archive
You won't have to look for it, it will find you my friend..
Or is it OK? I have
You have done something which would not pass code inspection and which might just let an accident happen which will incrementally raise the cost of homeowners' insurance for all the rest of us. <G>
If you have an outlet 5 feet from the light location, and it has a ground running to it, it shouldn't take much work to remove the outlet and mount a metal surface mount box on top of the existing outlet box and then run metal conduit with black, white and green wires in it over to where your security light is. You could remount the outlet in the surface mounted box.
And, install a metal box behind the light too if there isn't one there already.
The URL you gave shows a MOTION detector light, yet you seem to be talking about a daylight sensing light. Are you sure you know what your wife bought?
If it IS a daylight sensing light, you might be able to eliminate the flickering by repositioning the direction the sensor is looking, or by fabricating and tacking on a little shade to keep it from "seeing" the garage door as much.
HTH,
Jeff
deja_bhoot2000
Usenet Archive
It is a "motion sensor / infrared heat sensor" security light that also has 2 other switches. So, it can function as motion sensor light, or dusk to dawn light.
The setting that I have selected means it will turn ON, only if
-- motion sensor sense motion; AND
-- Light sensor does NOT sense light;
Furthermore, if I walk by it in dark and it turns on, there's a built in timer which will turn it off within X (1 to 10 minutes), if there is no new motion.
John Grabowski
Usenet Archive
After a year or two when the extension cord insulation dries out from outdoor exposure and moisture gets in there, a lack of a grounding conductor will be the least of your worries. Water is a conductor and will cause a high resistive short that will not trip your circuit breaker, but will burn everything in contact with the wires. Since the wires are high above the driveway and are in the wall, they will continue to burn for a long time. By the time you notice you may have some serious fire damage.
As an example, last year I got an emergency call on a Saturday night from the maintenance man at a condo development that I service. Some of the street lights were not working and the circuit breaker would not reset. Sunday morning I went over and started checking all of the poles. One "Pole" was brand new and was nothing more than a 16' 6"x6" pressure treated log that their maintenance company put in to replace a pole that someone knocked over with a car. The work was not done by an electrician, but by a bunch of laborers. They routed out a groove in the side of the pole and installed 2 pieces of indoor romex spliced together without a box in the groove and covered it with molding.
When I disconnected that new pole from the circuit I was able to reset the circuit breaker and get the other street lights working. I then pulled off that molding covering the spliced romex and there was a big black burn mark in the center of the pole surrounding the open spliced romex. Water had gotten into the splices and made a continuous short until the heat caused the insulation to melt away and shorted the copper wires together which caused the circuit breaker to trip. The pole had only been in the ground a few weeks.
The same thing could happen to your house. Call an electrician and have that security light installed properly. That extension cord is not rated to be permanently installed and should NOT be run through walls.
John Grabowski
http://www.mrelectrician.tv
lisac
