Treadmill lubrication
F
Fentoozler
What would be a good (and readily available) substance to use for
lubrication between the rotating rubber mat and smooth bed of a treadmill?
I've tried Johnson's Baby Oil, but it doesn't seem to cut the mustard!
Angus
The3rd Earl Of Derby
treadmill? I've tried Johnson's Baby Oil, but it doesn't seem to cut
the mustard!
Angus
If I'm reading this right? wouldn't lubricating both perform a slippage?
Why do need to lubricate?
F
Fentoozler
The area requiring lubrucatiion is the area between the moving surface
(powered by a belt driven motor) and the flat non-moving surface directly
beneath it, therefore requiring minimal friction.
Angus
dom
Johnsons baby oil - are you serious or taking the p***?
That I would guess is vegetable oil derived so will break down/dry
out/become a sticky goo in air.
You need either a mineral based lubricant (wd40/lubricating
oil/vaseline/parafin wax - some of which may attack rubber - be
careful) or a dry lubricant (PTFE spray).
What was in there originally? What does the manufacturer recommend?
I'd have thought treadmills would use a sheet of ptfe plastic (or lots
of rollers) and run dry.
F
Fentoozler
Baby oil is parafin based.
dom
Apologies for tart tone - you learn something everyday!
Dave Plowman (News)
the mustard!
One lubricant which won't hurt rubber or dry out is red rubber grease used
in car hydraulic systems to lubricate the rubber seals on assembly.
It's available in tubes or standard grease tubs from good car spares
places or online from the likes of Frost.
http://www.frost.co.uk
and search on 'rubber grease'
Phil Hughes
Angus
One that I know of came with some silicone oil for this. Don't know how
easily available it is though.
raden
Or not ...
A water repellent - are you serious or taking the p***?
Dave Liquorice
Must be taking the p***, the last thing you want near real rubber is a
mineral oil. Personally I'd try powdered graphite or talcum powder.
Chips
Angus
Have I stumbled onto some cheap porn site ?
Rob Morley
Depending on what the 'rubber' actually is, there's a fair chance that
oils will seriously damage it. Clean the belt and the base thoroughly
with detergent then give them a good spray with silicone furniture
polish and buff it up.
Treadmill repair 0
Treadmill problem 8
Treadmill Vibration Isolation 4
treadmill stops after 1 second 10
Treadmill keeps stopping and stuttering! 0
PVC Lubricant 18
Silicone lubricant 18
Lubricating Oil 7
