bsheeres
Hi
I have a Trane "Gas-Fired Fan Assisted Combustion System" with
"Intelli-Ignite" home furnace (model TDE060A936KZ) that I believe is
reporting a false "Open High Limit Device" error. It will operate just
fine for days then suddenly report this error and refuse to ignite. It
may choose to do this upon startup in the AM while completely cold;
having been idle all night.
The reason I believe it's a false indication is that while it was
reporting the error I checked each sensor to see if was open and they
all reported closed. Also, usually, simply cycling the breaker for the
unit will cause it to resume normal operation.
The filter is clean and there is ample air-flow.
So the suspect now is the control board. Are there diagnostics that
can be run on these boards? Is this common for a board to just
malfunction like so? Is there a reset procedure?
Thanks.
Brian
Thanks.
Brian
