Toilet Seats
Samantha Booth
Mine is a plastic seat with plastic fixings underneath. It keeps slipping
dispite me tightening the fixings several times.
Is there a way to combat this, new fixings perhaps??
thanks again
Sam
RW
Fit a wooden one.
Warmer,
More secure (Usually)
and looks nicer
Rod
thanks again
As well as the hinge problems that are common, this sometimes seems to
happen if the "bumpers" that touch the rim are not well aligned. Check.
Unfortunately it can be difficult to replace/reposition them on a
plastic seat - usually at least possible with a wooden seat. For a true
bodge, you could (temporarily, I hope) use some ordinary silicone
sealant to form new bumpers. Let it set well *right through* before use.
Rod
Hypothyroidism is a seriously debilitating condition with an insidious
onset.
Although common it frequently goes undiagnosed.
<www.thyromind.info> <www.thyroiduk.org> <www.altsupportthyroid.org>
Adam Funk
Use Loctite (available from motor spares shops) on the threads just
before tightening the nuts.
Dave Liquorice
You need a good soft grippy something between the hinges and the pan. The
supplied plastic things are too hard. I've used bits of grip mat to
reasonable effect.
Not 100% but that is down to the rim of the pan being slightly dished in
and new seat having horizontal bump bits so there is quite a twisting
force on the seat hinges.
John
reasonable effect.
The holes in the pan (around the bolts) need to be filled with Silicone to
stop the bolt assembly from moving about.
K
k.dunbar
stop the bolt assembly from moving about.- Hide quoted text -
- Show quoted text -
B & Q do a three piece wooden loo seat for only about £7 which has a
very different way of fitting - the third piece of wood being screwed
to a metal and plastic frame that seems to be far more secure in the
two holes. So far my two haven't loosened or slipped at all. They
are only available at the bigger stores - and now I check on the
website I can't find it at all!!!!
Keith
Bruce
Ian said:
Seconded...this is the only proposed solution that actually worked on
ours
Since I decided to buy only those toilet seats that come with a bar
joining the two hinges together, I haven't had any problems.
You can buy the hinge set separately for £6.99 plus postage on the
well known auction site. It's worth it to avoid all the messing about
with the cheaper, inadequate hinges.
Adam Funk
I tried this. The studs snapped off completely rather than coming
undone. I know which I would rather happen.
Oh! I've never had that problem. Were the studs plastic too?
Dave Liquorice
Which Loctite did you use? There is quite a range, some allow disassembly
others don't (or put up a damn good fight...).
Adam Funk
The one I've used (the only one I have) is Loctite 243 "Nutlock" (not
for FNARRing), which is red.
Adam Funk
They were metal. I would assume that plastic would be even worse.
Sorry to hear that. I've never had screws, studs or bolts shear as a
result of Loctite (although I've seen them shear from rust). If I
had, I would've advised caution. This must be a YMMV situation.
toilet seats 4
Toilet seats? 13
Toilet Seat 12
Toilet seats 9
Toilet Seat 5
Toilet seat? 11
Replacing toilet seat 5
Fitting toilet seat 10
