Toilet seats
John Smith
I wish to replace a couple toilet seats, we want white plastic seats of
approx 420mm x 375mm and the important measurement is 225mm between the pan
fixing bolts - its a Twyford pan of unknown model number.
Any ideas where we may obtain such?
Thanks,
John
Bob Minchin
pan fixing bolts - its a Twyford pan of unknown model number.
Thanks,
John
Seats I have fitted have been adjustable over quite a range.
Never had to find a special to suit an unusual pan.
225mm does sound wide - just measured mine at about 170mm.
Maybe try a proper plumbers merchant not a shed.
Bob
John Smith
"Bob Minchin" wrote in message
Thanks,
John
Bob
Tried the one local proper plumbers merchants and a couple sheds without
success hence this post.
mike
Thanks,
John
Try a Google search ("toilet seat 225")? I found several sites with
questions asking for 225mm spaced seats, some had no replies, another said
the widest they sold was 220mm.
Then I came to this:
http://www.replacementbathroom.co.uk/twyfords-jupiterrhapsody-wc-toilet-seat-443-p.asp
which seemed a bit expensive and got me thinking that you are after
something rare!
Mike
John Smith
"mike" wrote in message
Thanks,
John
something rare!
Mike
Thanks for the reply Mike. As you say that IS expensive...may be forced to
refit
the original (only 15 years old) nice wooden seat!..whilst we continue to
look around.
John
John Smith
"John Smith" wrote in message
Thanks,
John
something rare!
Mike
refit
look around.
John
So far so bad!...I've failed miserably to locate a seat with fixing bolts
225mm apart (seems that 150mm is the norm). Any ideas?
Bob Minchin
John said:
in message
in message
something rare!
Mike
refit
look around.
John
bolts 225mm apart (seems that 150mm is the norm). Any ideas?
Get the type that are two mounts with a rod in between
Change the rod for a longer piece of stainless steel and fit two ss
spacers to centralise the seat & lid.
Bob
John Smith
John said:
in message
in message
something rare!
Mike
refit
look around.
John
The Medway Handyman
in message
something rare!
Mike
to refit
to look around.
John
You can buy screw on hinges for wooden toilet seats
http://www.diy.com/diy/jsp/bq/nav.j...mpid=4&tmad=c&ecamp=cse_go&CAWELAID=266881081
F
fred
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9270906&fh_loc
ation=//catalog01/en_GB/categories%3C%7B9372015%7D/categories%3C%7B93
72046%7D/categories%3C%7B9372180%7D/specificationsProductType=toilet_fitti
ngs/specificationsSpecificProductType=toilet_seat_hinges&tmcampid=4&tmad=c&
In case it helps in the future, B&Q website links to specific (single)
items can be truncated after the 7digit product ID code to give a
shorter link.
For the part you pointed at, this link will get you there:
Toilet Seats 11
toilet seats 4
Toilet seats? 13
Toilet Seat 12
Toilet Seat 5
Toilet seat? 11
Replacing toilet seat 5
Fitting toilet seat 10
