Testing For earth
F
Fester
I've just installed a kitchen and want to test the sockets for a patent
earth. I only have a bog standard multimeter. Is there a way in which I can
do it ?
Stu
AJ
do it ?
Stu
run a wire to your main earth connection near the meter then test
between the other end and your socket earth, basically add and extension
to your multimeter lead.
ARWadsworth
do it ?
Stu
What is a patent earth?
Are you trying to prove that the earth on the sockets is correct? If so
there there are ways using a mulimeter to ckeck a ring main.
HTH but I need more info.
Adam
PeteZahut
Adam
Just out of interest, how would a ring main be checked with a multi-meter
for continuity, ie all the live cables connected correctly etc?
What settings would you ser the multi-meter to?
Pete
Cheap Test for Earth Spike 3
Earth testing 10
Earth trip testing 8
Earth trip testing 1
Electrical testing (Earth) 12
Testing an Earth Rod 6
Testing for earth in a 3 pin plug 4
earth loop testers 1
