Tefal steam generator iron repair
Mike Faithfull
When all else fails, ask uk.d-i-y .........
The Management has asked me to repair a Tefal Express model 2911 steam
generator iron for one of her friends. The problem is that the fabric
sheath which normally encloses the mains cable and steam tube between the
base unit and the iron has lost its anchor point at the iron end and has
shrunk back, exposing the mains flex and steam tube for a distance of about
15 inches. In itself this would not be a great problem, but the user seems
to have abraded the loose mains flex, wearing through both the outer sheath
and the inner insulation on the wires exposing the copper conductors.
Clearly, this is very dangerous and the flex must be replaced.
Unfortunately, after several unproductive hours smurfing the Interweb I am
unable to find any listing for either this cable, or the complete sheathed
cable/tube assembly, on any website selling Tefal spares, and the only
0.75mm 4-core heat resisting cable rated to 90 degrees Centigrade I can find
comes with a white sheath, making me suspect that it's PVC rather than the
black synthetic rubber of the original, on a 50 metre drum at a cost of
nearly twenty pounds.
Please does anyone know where I could purchase just a few metres of said
cable? I live in Hatfield, Hertfordshire.
Aidan
15 inches.
No idea. Exactly the same thing has happened to mine. Let us know if
you find a spare please, I may need one shortly.
David Lang
Have you tried a) Tefal - after all, the bloody manufacturer should have
the spares or b) www.partscenter.co.uk
Dave
dave stanton
I am in the trade, but found it very hard to buy a few metres of non-kink
flex. I found these guys in Bristol and bought 2 mteres off the reel of 3
core non-kink. i know you need 4 core, but they may be able to help, give
them a ring
DES 01752 661634
Cheers
Dave
Mike Faithfull
them a ring
DES 01752 661634
Thanks for that, Dave. Worth a try, I guess.
Mike Faithfull
(snipped)
After much searching, 10 metres ordered on line from Alert Electrical. It
has PVC rather than rubber insulation but it's rated for 90 deg. like the
original, so should do the job ok (I hope!)
