According to meirman said:
Someone gave me a used push lawnmower with a Tecumseh 4-stroke engine. It has no points or condensor under the fly wheel, so I assume that means it has electronic ignition.
Is there a clear way to test the ignition coil/assembly to see if it is good or not?
I get no spark, afaict, using an inline neon spark plug tester.
Am I correct in thinking that repairing the ignition coil assembly will be next to impossible? And that buying a new one will cost more than any push lawnmower that is probably 10 years old is worth?
I didn't have any trouble getting carb parts (in stock no less) for a 6HP Tecumseh almost 40 years old. The parts were cheap.
You can test the coil yourself to a certain extent. Coils have three leads, one of them being the spark plug wire. The resistance between the two non-plug leads should be pretty low - a few ohms. The resistance thru the spark plug lead to either of the other leads will be fairly high, but not infinity.
This isn't a full test, but if it fails it, it's bad for sure.
A small engines repair place may well have a "proper" tester which is capable of proving the coil good.
[Our small engines night course teacher has a "real tester". Got to play with it last night.]
Repairing a truly dead ignition coil is virtually impossible.
One of the few things you can repair is cracked coatings on the winding (_not_ the wire insulation, but the outer weather shield). [make sure it's dry, and then coat it with RTV.]
Ignition coils aren't very expensive, you'll also find them pretty universal between Tecumseh engines of even remotely similar vintages. The link below says "These are just a few Tecumseh Ignition/Electrical Parts".
http://willardssmallengines.com/shop/tecumseh/ignition-electrical-parts/page1.html for example, lists several Tecumseh coils from about $25 to $45. A lawn mower probably uses the cheap one.
