Socket swap.
shazzbat
On our landing there is a light switch and immediately below it a "socket"
which was intended for an immersion heater which has never been used. This
is 1.3 metres above the skirting, and is the type with a switch, a removable
from outside fuse, and a hole in the bottom edge for a flex to come out. It
is supplied from the ring, not a spur. Is there a reason I shouldn't replace
this with a 13A socket, which would be far more use to us?
TIA
Steve
ARW
"socket" which was intended for an immersion heater which has never
been used. This is 1.3 metres above the skirting, and is the type
with a switch, a removable from outside fuse, and a hole in the
bottom edge for a flex to come out. It is supplied from the ring, not
a spur. Is there a reason I shouldn't replace this with a 13A socket,
TIA
Steve
There is no reason at all why you cannot swap it for socket.
Cheers
jagga009
