Siding question
c_kubie
Usenet Archive
I've seen siding put on in houses in my subdivision.
They pull off the siding. Then I have seen then tack up a shiney board (not technicial terms - looks like it comes in 4x8 sheets). Then tyvex wrap the house and put on new siding.
What is that shiney board they put on?
c_kubie
raven
Usenet Archive
Probably foil faced rigid foam insulation.
Polyurethane and polyisocyanurate are both closed-cell foams that contain a low-conductivity gas in the cells (usually one of the HCFC or CFC gases.) The high thermal resistance of the gas gives these foams an R-value of between R-7 and R-8 per inch. .... Foil and plastic facings on these foam panels help to slow the escape of gas from the cell structure. Testing suggests that the stabilized R-value of rigid foam with metal foil facings remains unchanged after 10 years. The reflective foil, if installed correctly, can also act as a radiant barrier (another type of insulation) that adds about R-2 to the insulating assembly. Panels with foil facings have stabilized R-values of 7.1 to 8.7 per inch.
John
Mike Dobony
Usenet Archive
Polyurethane and polyisocyanurate are both closed-cell foams that contain a low-conductivity gas in the cells (usually one of the HCFC or CFC gases.) The high thermal resistance of the gas gives these foams an R-value of between R-7 and R-8 per inch. ... Foil and plastic facings on these foam panels help to slow the escape of gas from the cell structure. Testing suggests that the stabilized R-value of rigid foam with metal foil facings remains unchanged after 10 years. The reflective foil, if installed correctly, can also act as a radiant barrier (another type of insulation) that adds about R-2 to the insulating assembly.
But this extra value is based on about 1/2" spacing above it. In theory, Double Duch siding should provide this, but that 1/2 inch needs top be sealed. Still, there should be some extra value there.
lisac
