shredding Ivy
Charlie Morgan
I have a property with a lot of english ivy that has run amuck. I want
to pull it up and run it through a chipper-shredder. I'm just
wondering if one of those 6.5 HP Troy-bilt units from Sears or Lowes
will handle ivy without jamming every 10 seconds. Has anyone ever
tried shredding this stuff?
Yes, I understand that the ivy will grow back. So will the stand of
bamboo I will also be cutting down and running through the chipper. I
just need to clear it for the short term. My only question is about
whether this machine will grind the ivy reasonably well, since it
looks like that might be a good question to ask, given the tough,
stringy nature of ivy.
CWM
trbo20
CWM
I do this with my mulching lawn mower all the time. It makes for great
compost. Take care to make sure it's completely shredded before
tossing it in a pile somewhere. A small piece left in the right place
can take root and start a new vine.
bill allemann
as long as the blades are nice and sharp and you run the unit at fairly high
rpms,
they will grind up nicely.
bill
N
nhurst
CWM
I usually take RoundUp to it and leave it alone for a few weeks, then
respray until it's dead.
Then again, I had a serious infestation, and nothing to lose except for
a bunch of English Ivy.
Charlie Morgan
Thanks, but I have about a 1/4 acre that is very thickly covered and
it has to be cleared away, dead or alive.
CWM
Colbyt
CWM
Not looked at the insides of the TB model. I can tell you for a fact that
the YardMachine type blades will not shred any viney material. It just
locks it up and you have to dis-assemble the machine to clear the clog.
Shreds other stuff fine but not vines. Green bamboo I think it will do.
Mowing the stuff in place and then raking might be your best option.for the
ivy.
Charlie Morgan
If you agressivly clear the ivy and continue to clear it for a few months,
it (the roots)will eventually die due to starvation without leaves. You
can't just cut it down and be done with it. A roto tiller will give it a
hard time too.
Oh, how I wish I could run a mower over it. Unfortunately, it's rocky, hilly,
rough terrain. I'm also not interested in any extra effort for a permanent fix.
We just need the area cleared for the short term. It can all grow back in a few
years and it won't matter.
Thanks,
CWM
Charlie Morgan
CWM
UPDATE: In researching which chipper/shredder to buy, I learned that
even the better consumer models will not handle Ivy or Bamboo. In
fact, the troy-bilt unit that was my first choice soecifically warns
against using it for those two things specifically. Vines and Ivy will
jam, and bamboo contains a lot of silica which quickly ruins the
blades. Oh, well.
CWM
Poison Ivy 26
Ivy remains 2
Help with Poison Ivy 7
Shred this 20
Ivy 13
Ivy 18
Shredded paper insulation 19
Ivy on wall 2
