Should I change my shwoer?
Strangiato
I have a Triton Bermuda electric shower. ("Inherited" from the people I
bought the house from.
BTW, I'm no DIY man.
When I switch it on it pours water out of, and only out of, a plastic pipe
sticking out of the bottom of the shower unit. Internal inspection doesn't
show anything "obviously" wrong. Is it worth trying to get it fixed, or
should I change my shower?
Thanks in anticipation :)
L
Lurch
For the price of a new one, and knowing what the triton spares hotline
is like, and considering you're not a diyer, get a new one.
SJW
A.C.S. Ltd.
H
Harry Bloomfield
If you mean the pipe which goes to the shower head, then either the
fexible pipe has split, or the soft plastic washer between this and the
outlet is missing/damaged.
Aldi are currently selling complete replacement heads + pipe
includuding the plastic washers for about £2.99
Tim Downie
Tony said:
Then you're probably best off asking a pro. Triton have their
own service engineers who we have found very good. Their website
(from where you can get all the docs) is at
http://www.tritonshowers.co.uk
From the FAQ "If water is leaking from a clear plastic tube at
the bottom of the unit, then the Pressure Relief Device (PRD)
has been activated.
Which can just mean that the temperature has been screwed to the highest
possible setting or that the showerhead is partially/completely blocked.
I'd check those out first.
Tim
BigWallop
You've probably blocked the shower head hose somehow or it's damaged on the
outer metal skin and is pressing against the inner rubber tube, or the
pressure relief diaphragm has just worn out with age. Make sure the shower
head and its hose aren't kinked or choked by limescale, if you're in a hard
water area.
Here's some instructions if you want to replace the faulty part. It's an
easy and very, very cheap repair to carry out if you follow these
instructions. Read them through first before you go do the job, just to
give you an idea of what is needed.
Look inside the main shower unit itself, making sure to turn the power off
at the mains, you'll see that the shower head hose connects to a removable
pipe at the bottom of the big heater (copper) tank thing. The removable
pipe is held in place by two screws (cross head) through lugs on either side
of the pipe near the tank end.
Put the plug in the waste hole or cover the waste water outlet with a cloth
before doing the next bit. Undo the screws and it will let you slide the
pipe out of the tank by pulling gently downward and lifting out toward you
as you go. Watch out that you don't lose the rubber washer on the very end
of the pipe.
On the back of the pipe you'll see two little bracket shaped things. These
actually hold the Pressure Relief Diaphragm in place on the bottom of the
heater tank. The PRD looks like a piece of plastic with a hole in the
middle. The hole will be covered with a very thin black rubber cap and it's
this rubber cap that is the actual pressure relief diaphragm. You should
see that it has a big hole through, well that shouldn't be there.
Now, if the shower head and its hose are all perfectly clean and clear, then
you can make a simple repair of the PRD by putting a piece of very thin
plastic sheet over it. The best and safest I've found is from the plastic
bags you get in super markets on a roll that you pull a bag off and put your
fruit in it type. Thin density and strength are almost identical to the
actual PRD, so it is safe enough to use as a replacement diaphragm.
Tear a small piece of the bag off and place it over the little plastic piece
with the hole in it, so the piece of bag doesn't need to be that big, making
sure it covers the hole and hangs over the sides of the plastic holder. You
can then push the plastic bit back in the hole on the bottom of the heater
tank.
Now offer the pipe back to the bottom of the tank, making sure not to
wrinkle the rubber washer on the end, and when you pop it in you put the
screws back in the lugs and tighten them up, not to much, until they hold
the outlet pipe back in place.
Turn the power on and try the shower. Yippee !!!! It works perfectly.
Doesn't it ?
http://www.basecuritysystems.no-ip.com
Version: 6.0.572 / Virus Database: 362 - Release Date: 27/01/04
John W
What is the Triton spares hotline like? I need a spare and was going to go
direct as the two companies I've emailed don;t seem to want my business. Do
you know of any alternative trusted suppliers (I only need a new Can
Assembly which is obviously a simple DIY job to replace)
L
Lurch
If you know what you want they're not too bad. I just wouldn't
recommend a total novice with no idea what they want calling them.
SJW
A.C.S. Ltd.
Strangiato
You blokes are brill for giving me these detailed answers. Thanks! Also
thanks for putting up with my misspelling in the subject line!
BigWallop
The subject line is the only bit that spell checker misses when you check
the message. :))
N
ng_abuse-subscribe
Harry Bloomfield retched Should I change my shwoer? onto my recliner:
I always find a good thumbing does the trick.
Maybe you should replace your head, it seems to be faulty.
