Self Cleaning Oven - Just Say NO!!
Charles Pisano
I recently purchased a (new construction) vacation home and it came with
a SC oven. I've never bothered to buy myself one of these so I was
unfamiliar.
I attempted to use it the other evening and quickly became sick from the
fumes even though I had opened windows. After doing very little reading
(about small birds dying etc), I quickly realized super heating the
Teflon in an oven (or any teflon) to save oneself the trouble of
getting in there and cleaning it is not worth the potential harm to me
or guests.
Anyone is better off not using this feature if you happen to have it.
The chemicals can also be absorbed in upholstery and carpeting etc and
then later absorbed through the skin.
Like cell phones and computers and microwaves, these types of ovens have
only been around for a relatively short period of time. Don't be a lab
rat for future generations.. As a further precaution, I'd recommend not
cooking over 350 in it either..
CP
Pat
unfamiliar.
or guests.
CP
You are supposed to kill the bird BEFORE you put it in the oven.
N
nhurst
At the risk of feeding a troll, I'm going to respond.
After some quick research (http://www.omega.com/techref/fluoro.html)
I'm going to say you're mistaken:
Teflon doesn't burn until at least 500 degrees fahrenheit, which is
hotter than most ovens go, except when cleaning, and then it goes to
557 degrees or so. The few instructions on using a self-cleaning oven
I've seen state that you should remove everything from the oven before
you begin the self-cleaning process.
Yes, Teflon will burn on a cooktop, because burners get hotter than
ovens to, but again, instructions state that you should not leave empty
cookware on active cooktops.
As to the rest of your stuff, you do know that microwave ovens have
been around since the 1940s, right? And that in a properly used
microwave oven, no microwaves escape?
And for mobile phones, they were around in the 1940s as well, and only
became "cellular" when phone companies wanted to reuse the phone
frequencies, so broke urban areas into "cells".
Here are some Teflon and related links that should illustrate my point:
http://www.stanford.edu/dept/hds/shs/images/ovencleaning1/self-clean-cycle-2.pdf
http://en.wikipedia.org/wiki/Teflon
So in short, you're allowing yourself to be used to spread baseless
FUD. You probably have more to worry about in ingesting the aluminum
content in your teflon-coated cookware than Teflon itself.
-Nathan
E
Edwin Pawlowski
or guests.
As a further precaution, I'd recommend you educate yourself. Self cleaning
ovens are NOT coated with Teflon. Yes, the gunk in hte bottom will burn and
stink, but it is NOT Teflon so your don't have a clue about cooking in them.
Chris Lewis
or guests.
_What_ "teflon in an oven"?
There is no teflon in ovens. What you may think is teflon is an enamel
coating which is designed for the temperatures of self-cleaning.
There's only teflon in an oven if you leave a non-stick pan in it.
Which you aren't supposed to do if you read the instructions.
F
Frank
unfamiliar.
or guests.
Pyrolysis products whether from Teflon or other organic materials will
kill birds because of their very high respiratory rate. That's why
they used to use canaries to detect poison gas in mines. Pyrolyzed
Teflon will give you "polymer fume fever" which is flu like symptoms
that go away.
Your supposed to use you oven vent or fume hood, whatever. My wife
often forgets when cooking and often tests the smoke alarms ;)
Frank
sonofabitchsky
unfamiliar.
or guests.
Or drinking diet coke, or going outside while its raining, or taking
virtually any chances in life. Live in a bomb shelter and have a happy
fruitful life full of emotions!! Yay! Sign me up!!
Jack
unfamiliar.
or guests.
Its sad but some humans are as dumb as they come. I'm betting you
graduated from HS in the 70"s
E
Eigenvector
What is it about people and the need for an enemy in their life. From the
Wikipedia
"While Teflon itself is chemically inert and non-toxic, Teflon begins to
deteriorate after the temperature of cookware reaches about 500 °F (260 °C),
and begins to significantly decompose above 660 °F (350 °C). These
degradation products can be lethal to birds, and can cause flu-like symptoms
in humans (see Teflon flu). By comparison, cooking fats, oils and butter
will begin to scorch and smoke at about 392 °F (200 °C), and meat is usually
fried between 400-450 °F (200-230 °C), but empty cookware can exceed this
temperature if left unattended on a hot burner. A 1959 study, conducted
before the FDA approved the material for use in food processing equipment,
showed that the toxicity of fumes given off by the coated pan on dry heating
was less than that of fumes given off by ordinary cooking oils.[5]
A 1973 study confirmed the FDA findings and found that a 4-hour exposure to
the pyrolysis products of butter in an uncoated pan at 260°C were 100% toxic
to parakeets, whereas no deaths were observed for exposure to Teflon
pyrolysis products until the Teflon coated pan was heated to 280 °C.[6] Over
the 40 years non-stick cookware has been in widespread use, there is only
one published case of a minor, short-lasting health effect in humans linked
to overheating non-stick cookware.[7]"
Pat
I've never bought a new oven (how sad is that) but I wonder if they
don't coat them with wax or oil to keep them nice and shiny until
they're installed. Maybe it was just something like that burning off.
Chris Lewis
Why would they do that? Most times you don't see the thing until
it's installed. Wax or oil would cause a major stench even
without self-clean.
As have the occasional time where disgruntled employees in the
factory have smeared the insides of a oven with soap. Doesn't
need self-clean to produce incredibly noxious smelling smoke.
I may recall incorrectly, but didn't he say that he'd not used
the self-clean for three years? If you start with a very dirty
oven (eg: lots of broiled steaks) and self-clean, it'll also be
pretty noxious as the spatter burns off.
We run ours about once a year. With all the windows open
and the vent going. Sometimes sets off the smoke detectors.
Guest
unfamiliar.
or guests.
CP
I don't know about teflon in an oven, but self cleaning ovens with the
usual enameled finish have been around for at least 20 years.
mm
In the 40's through 80's and maybe a bit longer -- certainly longer
for most people -- the transmitting antenna wasn't held an inch from
one's brain.
Pat
without self-clean.
"I recently purchased a (new construction) vacation home"
trader4
The only way teflon gets into an oven is if you put it there. The OP
is either completely stupid or a troll.
U
user
Frank
When the smoke alarm sounds, that is the signal that supper is ready.
N
nhurst
one's brain.
While true, they were also broadcasting at a much higher signal
strength. IIRC your cell phones today are measured in milliwatts. The
older ones were measured in watts.
So while it's closer, the intensity is much lower.
-Nathan
Jim Yanik
(e-mail address removed) (Charles Pisano) wrote in (e-mail address removed):
unfamiliar.
or guests.
CP
What teflon is there inside an oven cavity?
You're NOT supposed to leave your pans in there.
