Seeking a 24V AC adaptor
D.M. Procida
For Christmas lights - the original says on it:
In-Li Industries Co. Ltd
Model48. YL-20-24V
INPUT 230-240V ~50HZ
OUTPUT 24V~ Max 20VA
That should be easy enough, but the connector is similar to the kind
that some old stereos used for their speakers - a flat spade, next to a
round pin.
Any suggestions where I could find a suitable replacement?
Thanks,
Daniele
Dave Plowman (News)
Model48. YL-20-24V
round pin.
The plug is known as a DIN speaker plug and can still be bought from
Maplin, etc, if you can find a PS with the wrong one.
However, I've seen this connector used on low voltage lights before. Dunno
why - it's an awful device.
Geo
Model48. YL-20-24V
round pin.
Cannot see the pictures on this page for some reason but there is a24v 20va
transformer listed:-
http://www.discount-christmas-decorations.co.uk/acatalog/Replacement-Transformers-For-Premier-Xmas-Lights.html
or use
http://tinyurl.com/3996u4m
Cut the DIN speaker socket off the old transformers and wire to the replacement?
Otherwise DIN speaker plugs and sockets available on Ebay (have not checked
Maplin).
Or cut the DIN plug off the lights and fit a standard (possibly 2.1mm) DC power
in-line plug to suit the new transformer.
O
Owain
Model48. YL-20-24V
http://www.maplin.co.uk/Module.aspx?ModuleNo=240&OrderCode=L55BR
24V 1.5A - " also includes a 2-pin mini-din socket, commonly used on
fibre-optic Christmas trees"
round pin.
How similar? Could it actually be a DIN speaker plug?
http://www.maplin.co.uk/Module.aspx?ModuleNo=935
Maplin appear not to list a 2-pin *mini* DIN.
Owain
chrisj.doran
*Life is hard; then you nap
    Dave Plowman        (e-mail address removed)           London SW
I have a couple of sets of lights using these, and confirm that it's a
DIN speaker plug & socket. I can only assume that they're trying to
use a different plug for each voltage, which is desirable if you're
plugging things in round the back of the sofa in the dark.
As far as the OP is concerned, I wonder whether it's really worth
getting a replacement -- from past experience the shops will soon be
cutting prices on unsold sets, if they haven't already.
Chris
D.M. Procida
These were the only attractive Christmas lights I've ever liked. The
only ones I see in the shops nowadays are huge, or blue.
Daniele
Andy Dingley
Higher contact pressure than the concentric hollow plugs used for most
other low voltage supplies. For lighting currents, the hollow plugs
have a potential fire risk, especially if the plug is bent in the
socket so as to reduce the contact spring pressure even further.
It's also very cheap to assemble 2-pin DIN plugs on a moulding line,
as the terminals are easy to access before potting and can be done
automatically together on a bar soldering machine. Most concentric
plugs need to be hand-soldered.
Scott M
round pin.
Probably less hassle to cut the plug off and just solder them together
or use a bit of connector block.
Grimly Curmudgeon
We were somewhere around Barstow, on the edge of the desert, when the
drugs began to take hold. I remember (e-mail address removed) saying
something like:
Many Chinese makers are simply using the cheapest connector for the job,
with no attention paid to interchangeability and wrong voltage issues.
For example, many electro-bike battery packs are using an EU kettle plug
for charging - how effing stupid is that?
The Natural Philosopher
Model48. YL-20-24V
round pin.
The connector is a DIN speaker pleg. Not the greatest..but usable.
You should be be to source a 24v or 2x12V mains transformer easily. get
one a bit bigger than you need wire it ip, construct a cardboard box
around it and POT the lot on potting epoxy or polyester.
Result will be a sealed safe 'brick'.
because its certified for moderate current low voltage use. I agree.
Vile devioce. when I designed an amp in the 70s, they wanted them. we
wanted screw terminals or clip terminals. WE ended up with both..
D.M. Procida
something like:
Why is that stupid?
Daniele
D.M. Procida
20va transformer listed:-
I don't think that's an actual supplier - I think that it's simply
reposting some content in order to appear in Google searches, for the
advertisements at the top of each page.
For example:
Shipping And Handling < Insert information on your Shipping and Handling
here >
Reaching Us If you need to reach us, please email us using the link on
the store page, alternatively, you can call on 232514547 (International
+44 232514547) or fax us on or write to us at Discounted Christmas
Decorations Discounted Christmas Decoration Discount Christmas
Decoration ffffffffff United Kingdom
Daniele
D.M. Procida
Model48. YL-20-24V
round pin.
I guess that an adaptor described as:
INPUT: 230-240v AC 50Hz
OUTPUT: 24v AC 1200mA MAX: 28.8VA
would be a suitable replacement, is that correct?
If these are just AC transformers and aren't attempting to provide a DC
output, then I don't need to worry about their no-load/low/load
behaviour.
Daniele
D.M. Procida
Andy Burns said:
Because you could use a mains "kettle" lead to surprise the battery with
240V AC?
OK, the one thing I hadn't expected was that he meant the battery (not
the charger) had a mains connector built into it.
Wouldn't that be illegal in the EU anyway?
Daniele
D.M. Procida
Model48. YL-20-24V
Any reason why a 2V DC output wouldn't be satisfactory (for the
Christmas lights that this thing will feed)?
Daniele
Grimly Curmudgeon
(e-mail address removed) (D.M. Procida) saying
something like:
Why is that stupid?
Somebody somewhere will plug in mains to the battery pack, guaranteed.
Nice explosion and fire, iwt.
AC 24V 10A ADAPTOR 1
240v to 24v adaptor 1
24V dc to 24V ac 20
AC adaptor question 7
AC/AC Adaptor suppliers 16
Laptop AC adaptor 10
AC Adaptor needed 10
Ikea lamp AC adaptor 6
