Sears Lawn Tractor Brake Repair
Pavel314
I'm trying to replace the brake on my Sears 16 hp lawn tractor. It's a metal
band bent into a circle with a rubber friction pad on the inside. Two bolts
hold it to the arm that pulls one of the ends to tighten the circle on a
flywheel, stopping the tractor. I got one bolt off the old brake with great
difficulty, as the brake is on the side of the gearbox.
Does anyone know of an easy way to do this? Unfortunately, they don't have
an access panel to get in there so I have to work from underneath, as far as
I can tell. If anyone knows a shortcut, I'd appreciate hearing it.
Thanks,
Paul
Sears Lawn tractor won't start 6
Brake job on Craftsman Tractor 10
Lawn tractors 5
Sears Tractor in Winter 2
Sear Tractor will not Start 3
Lawn Tractors 4
Lawn Tractors/Mowers 40
Lawn Tractor Question 3
