sanding stairs - follow up with pics
O
olo
Hi folks,
An update on the project aiming to strip the paint, sand and varnish
pine stairs. I am only doing threads and risers. Stairs are leading
to front door and I want to paint them clear-satin (natural wood
look). I am not particurarly bothered with them being slippery - there
are no children and I can always have rubber strips or something
similar. I will post pics along the way and ask two questions at the
end.
I have started with stairs painted white on both sides. Sanded top
step with random orbital sander but found this very ineffective (paint
clogging sheets) and dangerous (possible lead paint).
http://tinyurl.com/38ssgq
Following your advice, I used Nitromors instead to strip the paint and
here is the result:
http://tinyurl.com/3dvl27
Then, I got to my random orbital and delta sander again and prepared
stairs for varnishing:
http://tinyurl.com/3xa6k6
Now questions:
1) wood on both sides is a bit lighter than wood in the middle
(particurarly noticable on risers). I can't help with sander anymore.
Will this darken equally under varnish or do I need to pre-stain the
sides with something ?
2) I plan to use polyurethane varnish (I need sth low maintenence and
long lasting). Should I use water or solvent based one ? Visiting
local shed there are only two:
- Ronseal diamond hard and
- Sadolin.
Both water based (because they say to clean the brush with water).
Looking at screwfix there are two as well:
http://tinyurl.com/3dhgm6
http://tinyurl.com/36xg6e
second one looks like it's solvent based. What would be your choice ?
I don't mind if it takes long to dry, toughness is my priority.
any help much appreciated,
Stuart Noble
olo said:
Hi folks,
end.
here is the result:
Now questions:
Varnish usually highlights the difference.
"2 part woodworking bleach" (Rustins?) is probably your best bet. Part 1
is strongly alkaline and makes everything darker. Part 2 looks as though
it's not doing much until it dries. It may not mask the shade change
completely but it will almost certainly be an improvement. Nasty stuff
so heed all safety blurb.
- Sadolin.
Rustins 2 part floor varnish if you want toughness and a genuinely clear
finish.
George
olo said:
Hi folks,
end.
Try some Nitromors and course wire wool on the dark part of the stairs,that
might bring it up more?
George
By the way...
Hope you have good neighbours on that side of the house?
Cicero
Hi folks,
An update on the project aiming to strip the paint, sand and varnish pine
stairs. I am only doing threads and risers. Stairs are leading to front
door and I want to paint them clear-satin (natural wood look). I am not
particurarly bothered with them being slippery - there are no children and
I can always have rubber strips or something similar. I will post pics
along the way and ask two questions at the end.
I have started with stairs painted white on both sides. Sanded top step
with random orbital sander but found this very ineffective (paint clogging
sheets) and dangerous (possible lead paint). http://tinyurl.com/38ssgq
here is the result:
Now questions:
(particurarly noticable on risers). I can't help with sander anymore. Will
this darken equally under varnish or do I need to pre-stain the sides with
something ?
2) I plan to use polyurethane varnish (I need sth low maintenence and long
lasting). Should I use water or solvent based one ? Visiting local shed
there are only two:
- Sadolin.
Both water based (because they say to clean the brush with water). Looking
second one looks like it's solvent based. What would be your choice ? I
Regardless of any other treatment I would suggest that you consider some
kind of protective cover for the leading edges of the treads. This is the
part of a step that bears the brunt of everyday wear and could quickly
become dangerous.
As far as the colour goes I would echo the suggestion of more Nitromors
treatment as you're probably seeing engrained paint residue rather than a
true colour discrepancy.
Cic.
robgraham
Hi folks,
end.
clogging sheets) and dangerous (possible lead paint).http://tinyurl.com/38ssgq
here is the result:http://tinyurl.com/3dvl27
stairs for varnishing:http://tinyurl.com/3xa6k6
Now questions:
- Sadolin.
http://tinyurl.com/3dhgm6http://tinyurl.com/36xg6e
If you do have to stain, you will need to find some equivalent wood
and do some testing. Pine is always difficult to stain
satisfactorily. One trick I've discovered is to stain pale pink first
(dilute red mahogany 4 : 1 or so) and then stain with light oak. All
the pine stains give too yellow a finish for my liking.
Rob
O
olo
cool - thanks for all your advice,
I will try Nitromors & wire wool first on the darker parts. Failing
that I will experiment with wood bleach.
Also thanks for suggesting rustins 2 part varnish as being tough, I
think it is this one we're talking about here:
http://www.rustins.co.uk/product.htm?chgprod=PCF
cheers
Stuart Noble
cheers
That's the one. Bear in mind that it's fairly thick, and will look like
a sheet of glass if brushed on and left to set. I prefer to massage it
into the surface with a rag, which produces more of a satin look.
Disgusting stuff to use. The fumes are mighty powerful, but short lived
follow up with exploding toilet 3
Follow Ups 5
Follow Up 1
Follow up on "Help with TV Please" 2
Behr follow-up 12
Firewood Follow-Up 2
Icemaker follow-up 4
microwave follow up.. 9
