Right way to wire up kitchen cupboard lights?
clangers_snout
I'm installing some under-cupboard lights and some that are on top of
the cupboards in my new kitchen. What's the right way to do this?
How is the twin and earth cable that supplies these lights meant to be
brought out of the wall? Do you just bring it out to a junction box
(presumably affixed to the top and/or bottom of the cupboard) and
connect the lighting off the junction box?
Or does the T&E have to terminate onto some sort of fitting on the
wall first (in other words is it not allowed to bring the T&E straight
out of the wall)?
Sorry if that's a bit jumbled but I hope you get the idea.
Thanks for any help.
Andrew Gabriel
out of the wall)?
My recommendation is to fit Klik S26 sockets (same size as architrave
switches) mounted horizontally on architrave back boxes slightly above
and slightly below the tops and bottoms of the cupboards. (Klik S21 is
a super-flush version, which recesses further behind the wall surface.)
e.g. http://www.discount-electrical.co.u...lik-lighting-white-3-pin-architrave-socket-6a
but any electrical wholesaler is likely to have them in stock.
Then use matching Klik P22 plugs with flex to the lights mounted on the
cupboard.
clangers_snout
e.g.http://www.discount-electrical.co.uk/product.php/23559635/klik-lighti....
cupboard.
Thanks Andrew. there's no doubt that that's a far more professional
way to go about it but do you know if the T&E out of the wall to a
junction box idea would comply with the regulations?
Your method is superior but I'll never need to plug and unplug the
lights, and the connections will be hidden, so a cheaper (if nastier)
method would suit me better.
Biggles
out of the wall)?
Junction box on top of cupboard and connect lighting off the junction box.
Previous kitchen had this arrangement and just had new extension with
same arrangement, all certificated by a sparky.
Biggles
clangers_snout
Biggles
Thanks for that Biggles. Can you tell me though how does the lighting
cable (the T&E) exit from the wall to the junction box?
H
Harry Bloomfield
Why not simply use a switched, fused, flex outlet spur unit fitted with
a 2amp fuse?
clangers_snout
(e-mail address removed) wrote on 09/09/2012 :
a 2amp fuse?
Certainly that would be the right way to go about it but is there
anything in the regs that forbids just bringing the twin and earth
lighting cable straight out of the wall and just plastering the chase
up to make good. So the cable would just emerge from the plaster. Is
that against regs?
Gloops
out of the wall)?
Hello,
The last time I saw something like that being done, was with two rails
bringing low tension, and lamps directly plugged onto them.
Of course you have to be sure your cupboard will remain wet.
Some ready equipment is sold for that, perhaps it is easier using it,
even if not mandatory.
Where I said rails you can use two metal rods, provided you choose the
gap between them to ensure they can never enter in contact. Provided the
conductibility is sufficient, you can choose them on aesthetic criteria.
Concerning the lamps, perhaps LEDs provide the best light / consumption
ratio.
Of course, this conception could not apply with medium voltage.
Perhaps you will wish to cover the rails except on contact places, in
which case the aesthetic criteria apply to the cover instead of the
metal rods. Maybe this applies rather for the bottom lights than for the
top ones, to be specified according to the form and dimensions of your
cupboard.
W
Woody
Gloops said:
(e-mail address removed) wrote, on 08th Sept. 2012 13:18 UTC
+ 2 :
Fit a standard ceiling rose onto the wall and terminate the T&E
in there. Then run suitable two or three core flex - depending
upon whether the fitting needs and earth or not - to the fitting
itself.
I'm sorry to say this but if you are having to ask this type of
question it suggests you are not really competent to be doing the
job yourself and would be better from a safety aspect to leave it
to someone who is.
jagga009
