riding mower/lawn tractor
Bonnie
I am thinking of purchasing a lawn tractor.
Those of you that own one....are you able to mow over (shred) your leaves in
the fall finely enough to either leave them on the lawn as mulch, or bag and
compost them?
My property really doesn't need a rider (144' x 85') but if I could do my
leaves myself (mostly oak which don't compost well unless shredded pretty
finely) it would nearly pay for itself in one season. Last year it cost me
$500 to have someone rake and cart off my leaves (a lot of trees). I'd like
to be able to shred the leaves, then put the bagger on the rider, ride over
them again, empty the bagger and dump them in a compost pile.
It will cost me nearly $500 to have someone mow this season (and that's only
once every two weeks). I would love to be able to compost my leaves but I
need to be able to shred them. The reason I don't mow myself is that after
the 1½ hours that it takes me in the heat of the summer, I am so wiped out,
it ruins the rest of the day for me. I know...I'm a whimp. (I'm 49, hate the
heat of the summer. I prefer 30° to 80°.)
Anyway, what are your thoughts on this?
Bonnie in NJ
RBM
I think what you have in mind will work OK, but you'll be emptying your
collector every couple of minutes. They make tow behind leaf vacuums which
you'd attach to an enclosed cart, which hold a lot more leaves. They cost
though. I have a large lawn with only a few trees, when the leaves fall I
mow them in a circular pattern around the trees, blowing them toward the
trees. This method works pretty well as I'm left with a pile of mulch around
the trees which I manually pick up and cart away. hth, Roy in NY
ds549
i have big trees and i cut the leaves up with my riding mower and leave
them on the ground every year. the key is to get a mower with a mulching
deck , and mulch every day the leaves cover the ground.if not fine
enough go over them again... if you wait till they are all down they
will be to thick to mulch, lucas
Pop
See inline responses:
(shred) your leaves in the fall finely enough to
compost them?
===> Sure, I do that all the time. Before I got my
present lawn tractor I'd just mow twice, a day apart,
to finish the semi-mulching stuff. Leaves especially
mulch in nicely. Also:
Many lawn tractors these days come with what's
called a "mulching plate" and "mulching blades", as
mine does now. The plate simply plugs the chute where
the grass clippings come out, and the blades have more
of a shape to create a cyclone under the deck so the
cuttings are held in the air until they're chopped so
finely they're not much more than wet dust, which falls
into the lawn and disappears quickly. It does an
excellent job with or without the plate for mulching.
The only drawbacks I've noticed are:
-- You have to mow a little slower and a little more
often for perfect mulch creation. You're not supposed
to cut more than a third the length of the grass at any
one time, so a neglected lawn might take a couple or
three passes if you want it all to mulch so it doesn't
leave obvious clumps of grass around.
-- Mulching works better the dryer the grass is.
Trying to mulch in the early day wetness of the grass
can leave clumps of cuttings around and end up
unsightly. It'll require another cutting later in the
dry to dissipate the clumps. If it gets too damp, the
grass can actually clump enough to plug the deck
unerneath because it gets so sticky, and the fine
cuttings build up on the tires like a quilt an inch or
so thick. And, the deck becomes a real bi_ch to wash
out.
-- Mulching requires keeping the under deck fairly
well cleaned out, as in a hose spray.
But, I like it so much, I do it all the time. I mulch
about an acre total, less the house, garage and a large
shed and it's a good way of feeding the lawn. Total I
mow the full 5 acres about three times a year but of
course only the house acre gets mulched.
If you mulch properly, you don't have to de-thatch
the lawn every year either - the clippings are so small
they just disappear right into the soil and roots. A
touch of fertilizer/weed killer in the spring, and
you've got a nice, green lawn that won't brown up in
the dry weather until long after other's lawns have.
My lawns stand out like a big sore, green thumb late in
the summers; everyone thinks I water all the time; I
seldom water except in dangerously dry periods, and
then only when I know the well levels are high enough.
On the other hand, if all you're worried about is
really the leaves & small branches, a chipper/shredder
is great. It's a lot cheaper (`$500, maybe less) than
a lawn tractor at $1,2000PLUS. We even shred our
newspapers and mail in it, and put it out front by the
road: The Amish take it and use it for bedding to mix
into the straw for the cattle. Never, EVER put wet
stuff in a shredder, though; it'll plug it in a hurry!
<g>
Oh, get one with an automatic starter: they're bears
to pull if they don't disengage the cutters! It's like
spinning a huge gyroscope to get it started.
Pop
MLD
compost them?
Bonnie in NJ
I get more than the typical ton of leaves in my back yard and the riding
mower has taken what used to be a three day raking job and cut it down to
less than two hours. I just ride in a circle throwing the leaves towards
the center. As the circle gets smaller the leaves are continually getting
chopped up. Eventually I end up with a band of leaves abut 3-5 feet wide the
length of the yard. It then takes less than a half hour or so to rake them
up and cart away. Fortunately, I live next to the woods (that's where most
of the leaves came from) and dump them right back to where they originated
from.
MLD
Jim
compost them?
I have a 30" Sears (Murray) riding mower. My lot is heavily shaded by
mature elms and oaks which demand payback in the autumn when those
leaves fall.
Equipped with a mulching blade I simply make two passes. Once without
the bagger attached to chop them up. Later with the bagger to clean
them up. This doesn't mean waiting until the last leaf has fallen to
begin the job. I generally try for once a week during the season. With
1/2 acre I'm usually done in about an hour or so. In my case I dump the
chopped leaves in the greenbelt to compost.
